skewing the dyno??
Show us some pictures of your dyno. We love pictures around here.
That's funny because when I dyno'd my engine I gained 26 hp from a header swap, 2 inch to 2 inch / 2-1/8 step headers ....then I wanted to run the exhaust as it would be in the car, so we removed the dyno exhaust....it picked up another 25 hp.... So, that's a 51 HP pick up total.
There was no messing with anything except for removing a restriction.
I'll be putting this engine back on the Dyno soon if you need proof.
What horsepower level you at?
I will when I get home. I have some on my phone but they aren’t too good.
Screw it. I’m sitting at the bank with my mom. When we finish here and I get back to the house I’ll look through the pictures on here and post the best of what I have.
I may have some videos on here too buck I know those suck buttermilk
here's one, with my jsc aboard.
Pretty surprising that there was 51 hp between different large headers at the power level.
2 inch with primary tubes as long as the fw hookers are big restriction.
I fairly certain I could make another 25 hp with 2.25 primary headers.
But, I don't think I'll fit those in the car as simple as the tti headers.
People dont listen. Engine builders with dynos tend to exaggerate numbers, just like head porters with flow benches do. Yall remember MRL? that was the biggest lier I ever saw post on the internet.
What ever came of him? Karma catch up?
I thought the difference between headers was 26 hp and the additional 25hp came when you removed the dyno exhaust. I might have that wrong. How exactly did you test that?
That's correct. I think a great set of headers could be worth another 25 hp is what i meant.
We did a few tests after break in and the tune was where it looked good.
Then swapped headers added 26 hp. Then I noticed something and wanted to see if my theory was correct and that's when I decided, unhook the Dyno exhaust and run without. That was 25 more hp
