340six
King Of Bling
I used Dot 5 since 1998.been running dor 5 for a decade +.
people claim that it doesn't absorb moisture so it kills calipers and wheel cyl. if you are that worried about it just bleed the brakes in the spring. dot 3 absorbs the moisture so now ya have it throughout the entire system. i originally went to dot 5 because it doesn't strip paint if ya get a leak.
I have a good Mighty Vac. The good metal one. Straight forward easy maintained
Note, not sure how the knock off are but brake bleeding is easy with it.
