Show us your'e nuts.I'm Abe normal and a perfect candidate for the nut farm. I like nuts.![]()
Its a welded steel manifold. So it was an easy fix. 1994 lincoln 4.6 32 valve going into 69 Mustank. Its wide as or wider than a 429. I could have found a 302 and put an overdrive behind it for less money.Is that steel to cast iron? and they look good.... what are they for? my readback button is broken
yeah.. that 4.6 is a really cool motor.. but screw that.. those engine bays are too tight as is...Its a welded steel manifold. So it was an easy fix. 1994 lincoln 4.6 32 valve going into 69 Mustank. Its wide as or wider than a 429. I could have found a 302 and put an overdrive behind it for less money.
At least the spark plugs come out the top. And oil filter is easy access.yeah.. that 4.6 is a really cool motor.. but screw that.. those engine bays are too tight as is...
dunno..i actually like ford small blocks, my FFR had a 351 stroked to 383 with AFR 205s and a procharger.. that thing made plenty of power. I don't see the advantage of that v6 other than to surprise people.. is it a turbo motor?At least the spark plugs come out the top. And oil filter is easy access.
5204's? The first time on-and-off was a nightmare. after that, bing-bang-boom! no time at all.
I gave her Charlie on her 16th birthday in '02. Memory has slipped a little since then
I sent you a Private Message yesterday..
Simple enough and it looks like a Mopar ECU on the outside I bet.What are your thoughts @halifaxhops . HEI.View attachment 1716389232
easy 3d printer partSimple enough and it looks like a Mopar ECU on the outside I bet.
Saw some of the Duke/Houston game yesterday, man that Duke kid's got game. Bad foul called against him but a lot more went wrong for Duke than that last bit of game. Also saw a call where ball was punched out and called in favor of Duke when shoulda been Houston ballWow.
Ladies hoops. UCONN destroyed South Carolina
Yes it does.Simple enough and it looks like a Mopar ECU on the outside I bet.
Duke losing is a win for meSaw some of the Duke/Houston game yesterday, man that Duke kid's got game. Bad foul called against him but a lot more went wrong for Duke than that last bit of game. Also saw a call where ball was punched out and called in favor of Duke when shoulda been Houston ball
And you people say I drive the bus into the ditch?! I’ve never made that request in hereShow us your'e nuts. View attachment 1716389177
@dartnabout5-ish hour drive. Could've done 4 hours interstate, but you don't get to see things like this going on the wide roads.
And you people say I drive the bus into the ditch?! I’ve never made that request in here![]()
Meant to do one this year but wasn't following college hoops, not even Zags. Glad Houston is going since they beat Zags tho, they have good D and don't know Florida so we'll see tomorrow nightDuke losing is a win for me
My bracket went into the dumpster in the Sweet 16.
