I know is difficult to suggest the ideal timing, however would like to know what you guys are running.
I am currently experiencing some misfiring, and I think it has to do with timing and fuel Octane relation.
This is my set up:
Engine Cubic Inches: 410
Compression Ratio: 11.5
Intake Manifold Brand: Indy Performance 360-3R
Intake Manifold Bolt Pattern: Single 4150
Cylinder Head Type: Indy 360 H1 Aluminum Heads
Intake Valve Diameter: 2.100
Exhaust Valve Diameter: 1.65
Fuel Type: Gasoline and Race Fuel mix ( 2:1) 2 Gallons 95 octane pump gas, 1 gallon VP race C12 or C14 fuel
MSD Digital Ignition with 38 Degrees Ignition Timing
Fuel Pump: Electric
Fuel Pump GPH Rating: 140
Camshaft - Intake Duration @.050: 255
Camshaft - Exhaust Duration @.050: 263
Camshaft - Intake Lift at Valve: .670
Camshaft - Exhaust Lift at Valve: .670
Lobe Separation: 106
Header Diameter (List size for stepped header in space provided.): 1 7/8"
What is your setup and how much timing and fuel are you running?
This is my set up:
Fuel Pump: Electric
