65Vart
What are you guys running 4 ply or 8 ply for Mickey Thompson fronts ?
( 68 GTS )
( 68 GTS )
Nah , I wish…..340I am running the 8 ply. I have a Hemi in it and run them due to the weight and I can run higher pressure in them.
Looks like from your pic you may be running a Hemi as well................![]()
The load rating for the tire should be right on the sidewall so you can see what they are rated for. IIRC, the M/T Sportsman 8-plys I have hold 60 psi pressure.Quick call to Hoosier East says my 18105 tire is 2 ply! And he says ALL there front runners are 2 ply. Havent had a problem. BTW I do not run inner tubes on the front.
Interesting - I've never seen a tire without a load rating. Here's from the M/T website for the Sportsman tires:No load rating....
Wow! The load rating on a couple of those mickeys is remarkably low. 3500 lb car with typical weight bias overloads two of those pairs of tires!Interesting - I've never seen a tire without a load rating. Here's from the M/T website for the Sportsman tires:
My thoughts exactly and hence why I chose the 8-ply Mickeys. And especially given my car is also street driven. Worrying about load rating on front tires at about 120 mph is NOT something I want to think about at the big end of the track either!Wow! The load rating on a couple of those mickeys is remarkably low. 3500 lb car with typical weight bias overloads two of those pairs of tires!
