harrisonm
In the last 50 years, I have rebuilt quite a few engines. Most were complete rebuilds with professional machine work, but two were freshen up builds. On the two freshen ups, I bought new bearings and rings that matched what was in there. For instance, If I freshened up a 340 that was 0.030 over in the bores and 10 10 on the crank, I would buy new 0.030 rings and 0.010 bearings. I would reuse the old pistons (I was luck both times that the pistons were OK) after thoroughly cleaning them. I lightly polished the crank journals and lightly honed each cylinder. Both engines ran great. One was a Chevy 327, and the other was a 340.
Here is my question. New 0.030 over rings might be a bit loose in a 0.030 bore that has miles on it. In this case, could a person buy 0.040 over rings and file fit them to properly fit each individual cylinder and then place them on the pistons and install them?
