MOPAROFFICIAL
If it has tits, it's a liabilititty.
I've used both these cams, Street strip, and I just wanted to share what I've found to work best for seat and open pressures. I'd like to hear what everybody else has been running.
I run 11/32 5.025/5.011 valves
150lbs seat @1.80
330 open @.500
1.437 Paw double springs, same as engle's dbls they sell for their .5-.575 lift solids. Probably made by pioneer or someone like that.
Anything less than those pressures has shown float or loss of valve control.
Everything I build I always either pull the rocker set myself and check the wear patterns on the valve stems or tell the customer to do so.
I still break the cam in with 120lbs seat and maybe 280/300 open.fyi
150lbs seat @1.80
330 open @.500
