AC blower mod for RB installation
grjammer
PA
I needed to do a blower mod and couldn't find any for an AC blower, so came up with this that worked better than expected.
I cut the radius at the rear of the AC box like most do for any blower mod. I only cut enough out to clear the wheel by 1/8 inch or so. I used a jig saw and drilled a few relief holes.
I searched Amazon for rubber isolators like the OEM install and ended up with some metric ones. I needed an inch tall and 3/4 diameter so got pretty close with a metric size and cost was about 11 bucks shipped for 4. Only need 3.
I disassembled the motor from the mounting ring and placed the isolators inside the ring instead of outside like OEM. This gained about an inch and a half, which is enough to enable use of my MP valve covers. I can remove and install the valve covers without any trouble.
First picture is the protrusion of the wheel into the void area between the AC section and the heater section. I had to drill out the 2 rivets and remove the sheet metal ring that fills this area. It is installed on the heater section.
I don't anticipate any issue here as the new foam gasket fills the area between the sections.
Next is a picture of the new isolators and how I put them inside the blower mounting ring. I was also able to use the new rubber gasket around the motor, but have to trim a slight amount that covers the vent hole on the bottom of the motor. I slid the wheel to the bottom of its travel on the shaft. There is no interference.
The finished product installed in the car. I did not take a before picture, but the valve cover was unusable with OEM installation.
Sorry for duplicate images, dumbass website won't allow me to remove them
You should move this to the Articles "How To" section! :thumbsup:
Can you add a pic of the insulators you bought too? Nice job by the way. I used a geo tracker motor. Its sits completely inside. Works well.
They are Uxcell 20 x 30 mm. I couldn't find a standard in the size I wanted. The less of a diameter than the 1 inch OEM allows the ring to install much easier. I included a pic of the OEM mount that is outside the ring vs. the new mount which I moved to give me the depth I needed. I picked up the equivalent locking flange nuts at the hardware store for 3 bucks. Could use a shorter stud, but didn't want to cut them if not needed.
Non A/C box. I had it posted on BigBlockDart site 10 years ago. They had a heater motor modification on there. I lost all my documents (Pics) on photo bucket. I did have to change the squirrel cage with one from Grainger. May not have been necessary though. I believe motor was from early 90's Tracker. Sorry, that's all I got. If I can find what I posted years back here I'll repost it.
