tcanin00
What are you guys doing for speed input for an OBD II PCM. I was running OBD I with a Standard Motor Products SC108 VSS and it worked fine.
When I converted to OBD II, the speed input was reading at about twice actual speed. I was advised on the Facebook group Magnum EFI Swap to send speed output to pins 25 and 28 of C2.
This didn't work for my PCM. I think because it's originally programmed for a manual transmission.
Just want to see what other options for a VSS there are. I'm currently running a 904 LU, but am planning on swapping in an AX15 in the future.
