standup303
How do I change the mechanical advance on this 440 Source distributor? I understand how to change the springs. But it’s set at 14 and I need 19-20 mechanical advance.
Beats welding up the slots…still trial and error thoughSee the circled tab. There's one on the other side. You bend these to limit the amount of the throw on the weights, thereby decreasing or increasing the mechanical timing. Kinda chinsey if you ask me, but that's how it's done.
I tell you how I'd do it if I JUST HAD to run that distributor. I'd drill and tap each tab and use a long allen headed set screw with a lock nut on it to adjust the mechanical advance. .........but then, I wouldn't use that distributor. LOLBeats welding up the slots…still trial and error though
Makes sense. Thanks.See the circled tab. There's one on the other side. You bend these to limit the amount of the throw on the weights, thereby decreasing or increasing the mechanical timing. Kinda chinsey if you ask me, but that's how it's done.
Ya good idea. $100 440 Source distributor. Get what you pay for I guess. MSD ready to run looking real good right now!I tell you how I'd do it if I JUST HAD to run that distributor. I'd drill and tap each tab and use a long allen headed set screw with a lock nut on it to adjust the mechanical advance. .........but then, I wouldn't use that distributor. LOL
Well since you have it OUT and APART, you can get it exactly where you want it. That's certainly what I'd do. You said you need 14, right? Then just limit the distributor to 7 degrees and there you go. You can use a school protractor and get it dead perfect.Ya good idea. $100 440 Source distributor. Get what you pay for I guess. MSD ready to run looking real good right now!
