Mini torker. I like that name.His junk did run good till it didnt and he beat it pretty hard.
Anyways here is a good question for a 318 mod.
Anyone ever mod a 318 streetmaster since in reality its cast like a mini torker if one works over the plenum?
J heads come in around 64cc with a 0.040" cut, they were 72cc before milling.Do you know the CC of your J heads after the .04” cut? That cam has a very impressive torque curve on Comps site in their test mule Chevy small block.
The runners look more effective without the pinch on #3 and #6 for bolt clearance. The plenum looks very nice after the modification too. Nice work.
You "build" 340's. You "upgrade" 318's.318……. “Upgrades”??
This would seem to imply that they were less than perfect as Ma Mopar installed them between the fenders.
That can’t be true!!
318willrun, I watched your budget 318 hop-up videos where you got your Duster running 13.90's with $500 worth of parts etc. This was great content, inspiring stuff. With this upgrade you ported a set of small port, small valve 675 heads. I'd like to know what difference there is in doing something similar, only difference is a set of mildly ported and cut 1.88/1.60 J heads?You "build" 340's. You "upgrade" 318's.
Thanks, it was a lot of fun! I've done 360 heads on 318's. They flow more. I didn't on that particular 318 because I set a goal of under 500 (spent 498 lol). I usually cut them .040 and I've never had to resurface the intake either. That was my experience.318willrun, I watched your budget 318 hop-up videos where you got your Duster running 13.90's with $500 worth of parts etc. This was great content, inspiring stuff. With this upgrade you ported a set of small port, small valve 675 heads. I'd like to know what difference there is in doing something similar, only difference is a set of mildly ported and cut 1.88/1.60 J heads?
90w gear lube for oil, finally makes 30psi when hot and fast idling.
i was reasonable, sorta.....90w gear is akin to 40 or 50 motor oil, which a slap *** wore out motor would probably want as to have some semblance of pressure. but the additive package in the gear oil could likely be detrimental to the soft metal bearings.
i'd say you'd probably want to analyze the oil when you perform the PM as to catch something before it goes round and brown, but we're well past that point.
I presume he asked ChatGPT for tuning advice.I don't know about you but the OP's post seems like a mess of information, figure might be easier with some back ground info.
I asked the bottle God....I presume he asked ChatGPT for tuning advice.
Ah, there's your problem. European beer doesn't know Mopars. Try moonshine instead.
I've never heard of a Hough loader before. Is it pronounced like "though"?THE MIGHTY 318 HOUGH LOADER!!!
"huff".I've never heard of a Hough loader before. Is it pronounced like "though"?
I was going to make a joke about it being used for the mothers of 318 haters, but I'm afraid that it might take more than even the mighty 318 for them...
I tried moonshine. And domestic beer. Everyone drinks it! My fridge is always empty!Ah, there's your problem. European beer doesn't know Mopars. Try moonshine instead.
Pronounced "Huff". They made first rubber tired loader & then bought by International Harvester in the 1950s.I've never heard of a Hough loader before. Is it pronounced like "though"?
