Steering Column Mods with Hemi Denny Coil Over Suspension
69Chrgr
Charger/Cuda
Midlothian, Texas
Does anyone have any pics of what they had to do for the steering column and a rack and pinion installation? I am using TTi headers for a coil over setup. Thanks as Always.
Yea, I show a few pictures of my set up on page 23 of my build and also on page 25. Sorry I don't have much more detail of the setup.
I did away with the stock style column and grafted in a rav4 elc-power steering unit so I have a few u-joints on my setup one under the dash just before the firewall and the two in the engine bay. The HDK setup makes this fab east, and its strong enough to be used as manual setup as well as assisted.
1965 MMP's Barracuda Hemi swap! The Ever Changing Build
Denny provides instructions with his kit. Very easy to follow.
Thank you!
I used a flaming river tilt column. If you take apart your original column the flaming river will slide inside the housing and you will be able to use the climb support and the floor support without spending all the extra cash. I will see if I have photos. I posted them before how I did it. Save a tone of money and kept all original mounts.
I did not use Hemi Denny but RMS I think they both use the same mustang II rack. I used the flaming river swivels reduced diameter no fitment issues.
