Ok I had to use a rubber mallet to run the glass up the channel in the vent frame. I just silicone grease and spray. The new sliders seem about the same as the originals so it must be thicker seals. I don't know if the glass will ever roll up and down with the crank or whether I will destroy the regulator breaking it in. Is this normal these days? Attached are pics of original vs repro (Classic Industries)
ps I've about had it with repro seals. The upper side window weatherstripping fits like crap and I just tossed some vent window gaskets and used the originals. The door seal clips (little white ones) aren't like the originals and don't want to slide in the holes. Save any original seal that you can.
