[WANTED] HELP looking for hardware
acidspitstormchild
california
Rating - 0%
0   0   0
brake caliper lost a bolt the other day. Can’t seem to find this style for sale at any hardware or auto shop. There’s a similar one for the 05-2010 ram or Durango but upon inspection it was the wrong size. If anyone knows off hand where to find this It would help me a lot. Thank you.
if jim @hemi71x doesn't have one, i probably do.
you have a length from under the head to the end?
there's two or three different ones depending on the caliper bracket.
Most consistent measurement I came up with was 51.75mm 2.0375 inch or 2 3/16 inch for the total length.
I came up with 1 and 12/16 for the thread length. Sorry about the incompetence.
Looks like a pretty simple bolt to make out of a hardware store 2" grade 8 bolt (assuming you couldn't find a 1-3/4" version in stock. Do you have access to a lathe? I could probably make one for you if needed.
I could order a 1-3/4. unfortunately the stores near me did not have one. Went from 1/4 to 1/2. I also do not have a lathe. I certainly wouldn’t mind having one made! I should probably get a few of them.
Let me know if you have trouble finding them from a member and I'll see if I can find something I can modify for you.
To be perfectly honest, I'm not even sure the nipple on the end is even necessary. I'd just buy the next size up, cut it to length, and give it a shot.
For some reason my post disappeared. If junkyardhero doesn’t have any I’ll get back to you. Thanks for the offer
