Icetech
No.. i wish i did.. i never once had a issue with drums, did a disc/drum upgrade.. mopar slider calipers, everything is new, ebc yellow pads (just trying to see if it would help) 3 different MC's.. the one now is a 15/16 from Cass.. Pedal ratio is 6:1.. i finally bought a pressure gauge and i'm only getting 400psi at the calipers and they need around 1000... haven't figured why. Bled it like 10 times now. New distro block and wilwood proportioning valve..You got drums on all 4?
Some guys dump on drums but when setup properly they work great. Thought i would just do discs on this one. Ended up costing a ton for brakes that give a slight hint of slowing...
When i get my FFR cobra it felt like this.. on that one it was the pedal ratio...
