Moparman485
Active Member
Afternoon guys and gals
1973 dodge dart custom with AC, pepped up 360, soon to be 8.25 rear, and 904 trans.
Car is mostly street use but will be pushed at times for lead foot pleasure.
Pulled my original radiator to take it in for a flush and possible recore but discovered heavy corrosion all over and the side supports basically fell off during removal.
I plan to likely keep the factory fan/clutch and shroud. but want to know what yall have had good luck with as far as radiator replacements.
I would prefer to keep the factory shroud and hose/hookup locations.
With the market flooded with aftermarket aluminum and options, I wanted to ask the experts what they have had good results with and recommend.
Thanks!
Located in Oklahoma so summers get hot, but not extreme.
As always, part numbers or links would be greatly appreciated.
Thanks!
