Builderguy
Today was also wash day.
Gotta say, that turned out well! I've used it it motorcycle tanks before but you have to make sure you neutralize it well as you said. How many gallons in the bucket?Time for some Acid! Not the acid from the late 70's; nope, the good stuff that eats rust and pot metal. This stuff:
I use it full strength, but don't put any light metal in it unless you are ready to pull it out right away, or it will dissolve. I found out the hard way.
Anyway, it does a great job. I usually dip stuff for 10 minutes, then move it to a tub with a lot of baking soda mixed in water. Four or the big boxes will work. And after a 5 minute soak I move the part to clean water to make sure all the acid is neutralized. Being under water will also stop the part from flash rusting. I can then take parts out one at a time and blow dry them. From what I have seen, this stuff will not remove grease. So what does it look like?
View attachment 1716438815View attachment 1716438816View attachment 1716438817View attachment 1716438818
View attachment 1716438820View attachment 1716438821View attachment 1716438822
I can look when I get back home but I would guess those blue buckets have about 10 gallons of water in them. The one to neutralize has about 14 lbs of baking soda mixed into that 10 gal of water. I can give the exact amounts tomorrow. I finished the last piece I need to acid clean so I then dump the acid into the neutralization bucket (very slowly as it foams a lot). I then let it sit overnight before checking the PH with a pool test strip. Once it balanced, I can dump it out back.Gotta say, that turned out well! I've used it it motorcycle tanks before but you have to make sure you neutralize it well as you said. How many gallons in the bucket?
I know why they came up with this (trying to avoid installing air bags) but it was subject to so much failure that it was quickly bypassed. Like one of the PO's did. Now I have to remove his/her modifications, removing the blue jumper wires and toggle switch, and installing another bypass that is not seen and that does not require any user input. My understanding is that this safety belt interlock was only used in 1974. Fun to be had by all! Almost forgot, Happy Easter!
Man, that is the cat's pajamas! Is that going to be permanent or just temporary? Love how much space you have in your shop to work. I can barely squeeze around the sides of my car!Plastic is up, except for the filter wall and doors. Every other stud is taped and stapled. Scaffolding is down and put away, the rest I can get off ladders. I will line the inside with some white sheeting to brighten it up. The exhaust fans arrived today so a little wiring is needed. Soon, very soon. May just have to make this permanent, just need some sheathing on the outside.
View attachment 1716441256View attachment 1716441257View attachment 1716441258View attachment 1716441259View attachment 1716441259View attachment 1716441260
