Trunk repair panel
PatrickM
Member
Missouri
Does anyone make a repair panel for the area behind the shock mounts and ahead of the spare tire well?
No, the over the axle pan extends to and overlaps the trunk pan. They are the only pieces I've seen available for that.
That’s what I figured. I guess it’s time to get some sheet metal. I’m going to replace the trunk floor, extensions, and the tail panel with a 73 and back
Yes, it does but my that section of floor is solid except for that rear section. I would rather not replace it.
I hear you. They no longer sell quarter skins or lowere patches at AMD. they expect you to buy a full quarter and cut out what you need if you don’t need the whole thing.
Same idea with the floor pan. You’d just cut out the section you needed. Obviously not the cheapest option but it’s an option
I’ll make one out of sheet metal. It doesn’t have to look perfect. I really need quarter skins too. I might try goodmark for those
