[WANTED] 69 barracuda 14 X 5.5 inch wheels
Need 2 wheels dated Nov 1968 . Please let me know what you have
Thanks
Not sure if you want a regular steel wheel or rallye, but I have a set of 4 used Mopar rallye wheels here. 14" x 5.5" small bolt pattern. They're not easy to get to, so I pulled out one to look for dates codes. Is the date code shown in this shot?
Looking for the steel wheels . Sorry I didn’t make that clear in the post . Appreciate you looking
I have 1 that I know for a fact is from a 69 Dart GTS. The picture shows it with the tire mounted on it still but, I have since removed it. I'm in Lower Bucks Co., 19030 Zip code.
$35, you can come & get it. I'm about an hour ride from Sellersville.
I'll see if I can clean the paint off and get the numbers and then send you a picture tomorrow.
I had to go down my basement to finish some laundry, so I took these close ups. It's hard to make out but the number to the left of the valve stem hole looks to be a 9.
I know for a fact that this wheel came from the trunk (spare tire) of a 69 Dart GTS 340, that a friend still owns & is this rare color from the factory.
Let me know when you want to come & get it & I'll PM you the address info.
