Packard type 56 terminal end (male)
cudajim
cudajim
Grass Valley, Ca.
I need to fix up my connector at the firewall on a 69 Barracuda, I have a broken terminal end. I cannot find one in town and I'd like to have it made out of brass or copper, not aluminum. Any leads would be appreciated. Thanks in advance.
You have to be careful with Packard terminals. LOOK CAREFULLY at your female ends. On my 67, I believe ALL of them had the "curls" down along the sides of the female ends. rather than the sort of "flat" folded over, or the tab folded back over the end. They will not fit the housings and lock into them. In the bottom right last photo posted above, that is the correct one, at least for mine.
On later cars, there seems to have been other connectors using other types
Look around the site here. Mattax has posted a great thread on these
Thank you all for the feedback. I ordered a pack of 10 from Summit. The shipping costs more than the parts. I was getting no connection at the firewall for my oil pressure. The male end just fell apart so time for a new one. I'll also tighten the female end if I can get to it.
Just my opinion, I would be tempted(we installed a triple gauge set) to change to a mech oil psi gauge.
My reasoning....
I dont trust 60+ yr old gauges
under dash work is not fun
an aftermarket triple gauge set doesn't look outta place and it allows you to leave the oem gauges in place.
My reasoning....
Actually, I do trust 60 year old gauges if I know it's all wired and tested properly. This particular car has had the IVR replaced, all gauges tested on the bench too. It's the firewall connector giving me just a bit of a problem. I just don't like the look of aftermarket gauges hanging below the dash.
