Kelsey-Hayes 4 piston brakes question
Just for thought.....the greese / oil shevle at the Estate Sales is where I pick up the cheap to use on a project stuff....
Trying to clean up and re-seal my KH disc brake calipers and finding all four pucks on each caliper are stuck. I tried the usual trick of trying to blow the pucks out with 120 psi compressed air-not responding. I've read some people remove the bleeder, install a NPT zerk and pump grease into the cylinders but this sounds messy as hell and a waste of grease. Going after the pucks with a XL Channelock pliers sounds like a recipe for disaster as well. Anyone have any tricks up their sleeve? (no, I don't have a DOT-3 pressure pot)
I got your pistons boxed up and ready. I threw some boots in there I found, too. Send me your mailing address.
