[WANTED] I need these clips for 73 Dart 4 door custom rear glass molding.
dodgemahal
Illinois
Rating - 0%
0   0   0
3/4" x 5/8". They have the grooves for the 'nail heads'. Used ones are fine, as long as they're not severely corroded.
I have a brand new set for a 72 Dart Swinger I had & didn't use. Precision MFG. makes them. They aren't expensive for the kit. I think 2 door & 4 door use the same clips.
Sure, I have no use for them anymore. Let me dig them up tomorrow & measure them, then match them up with the picture you have. If they're the right ones, I'll give you a good price shipped to you tomorrow. How many do you need?
I grabbed what I have this morning. Not even close. They are screw on type & different dimensions. They are made by Precision though & they probably have the ones you need. Sorry I couldn't help you out.
That's okay. I appreciate you trying to help me. Can you tell me the dimensions of the screw-on style you have? I have holes for those on the sides. Nail-head posts at the tops and bottoms. Weird.
OK, small are 3/4" wide x 1/2" high. Large are 3/4" wide X 13/16" high.
Let me analyze this, then I'll contact Precision. If they don't have what I need I still might hit you up, if you would indulge me. Thanks!
Not sure if these are correct but you might check eBay with this number: 6002893
