[WANTED] SMALL BLOCK ENGINE BRACKETS/MOTOR MOUNTS
poorhouse
Active Member
Rating - 0%
0   0   0
Fer the love of God! Can't believe these are difficult to find. Have a Mag 360 going into 71 Duster. 318 brackets would be fine. Appreciate any help
I believe a magnum 360 takes 318 mounts both sides unlike the LA being different for the left side 340-360, From me to Nevada would be to costly
GASP...$189???!!!
Have you seen what people are asking for the OEM pieces lately.
189 isn't a bad deal with all the hardware.
Measure the upper ear spread (rear side to rear side) on both sides of your block, if the same width, you need the easily available 273-318 brackets. Drivers side more narrow, pony up for the 340-360 brackets.
I was taking 318 mounts, cutting them up and making them into a 340-360 compatible mount. Many on pretty stout SB's, no issues, knock on wood!
An issue with some 318 mounts is they do not have the hole for the rear upper ear.
340
318
