Brake caliper ID help
poorhouse
Active Member
can anybody ID this brake caliper? came off front right. looked all over/no luck. appears to be #'s 4556C. 3688, 3689, OR 3699 bottom left. and 982 bottom right. the driver side is different. pn# 184068CB THANKS
Don't know about the numbers, but the type is for '73-'76 A body (and some B/E & F/M/J bodies too?).
And yes, the left and right sides are different.
The casting number is 3699962 which is found on 74 and 75 Abody calipers on the right side.
Chrysler catalog part number is 3699968.
Will also work on 73 models but they had a different number.
thank you
