mopower440
440 .030 over
TRW 2355 pistons, 2.062 compression height, around 9.5:1
MP 284/484 cam installed at 104 (4 degrees advanced)
Bone stock 452 heads..no milling or porting.
Holley street dominator
Demon sizzler built TQ
1 7/8 fenderwell headers
3000 stall convertor
This is in a dart swinger. So I cant get rid of the pinging at the very last 1/8 throttle. Its fine everywhere else. I can stab it and no pinging but when i put that last bit into it, it pings. Even with secondarys open, its fine until i try to shove the pedal through the floor and it pings..Its like the secondarys are open most of the way but that teeny last bit makes it ping, but it also has a good little bit of power in that area. So if i want to richen up that last bit of the secondaries, wouldt i want to tighten the secondary air door more so it takes more to drop it open? The carb was built to the engines specs. So i sent off for a curved distributor to Ron at Halifax and it did help because it was worse but its still there. Its at 16 initial and 34 total. I believe its all in by 3200 rpm. Im thinking it has to be a slight lean spot on that last bit of throttle blade opening since there is no pinging at any other throttle position no matter how quick you stab the throttle. Its so aggrevating, i mean, i can stab the throttle to the carpet and no pinging, but then push down hard and it opens that carb that last little bit and it does this and there seems to be a nice bit of power right there..This is running 93 octane pump gas..i would think 9.5:1 could be fine on that..
