MidnightSwinger
Thought I would share this for the rest of you to admire on my new to me 5.9 magnum I just picked up.
The threads aren’t into the nylon on the nyloc, but other that that? Send it....and just what's wrong with that? Perfectly acceptable in my book.
stack of washers can be forgiven. but not engaging the nylock? shameful....and just what's wrong with that? Perfectly acceptable in my book.
I like poly, and the insert is the same as big block I believe?I just bought a pair of 340-360 spool motor mounts at Rockingham to avoid being shamed for doing that....lol. Now I just need to figure out where to get new inserts cause the rubber is shot!
Easily fixed.stack of washers can be forgiven. but not engaging the nylock? shameful.
yeah, it is. however it brings to the front of my mind if something as simple as this was overlooked, then what else did they bobo up?Easily fixed.
The motor was in a Non-Mopar application. I don’t think he knew 340/360’s use different mounts. 72 international scout.yeah, it is. however it brings to the front of my mind if something as simple as this was overlooked, then what else did they bobo up?
that's just lazy and hack work.
4wd guys... say no more...The motor was in a Non-Mopar application. I don’t think he knew 340/360’s use different mounts. 72 international scout.
Yeah he didn’t touch anything internally! Thank God!4wd guys... say no more...
(it's hacks all the way down)
[no worries on the mechanical part of the motor, everybody knows 4wd guys don't do no engine work]
No it was blueWas the scout primer grey? I put a built 360 in a 72 scout when I was 17. Transmission was dodge up front and international in the back.
1974 DODGE DART 5.9L 360cid V8 Motor Mount | Shop Now at RockAutoI just bought a pair of 340-360 spool motor mounts at Rockingham to avoid being shamed for doing that....lol. Now I just need to figure out where to get new inserts cause the rubber is shot!
yep, that's what loctite is forEasily fixed.
yep, that's what loctite is for![]()
Aren't they all primer gray?Was the scout primer grey? I put a built 360 in a 72 scout when I was 17. Transmission was dodge up front and international in the back.
They sure end up that way!! HahaAren't they all primer gray?
I’ve looked into the rock auto mounts for 360 and I believe there the 318 style. If someone wants to verify they’re really 360 specific mounts I’ll buy a set in a hurry!
