Brainstormin' 440 vs 5.9 ...
adding fishmen67....
TT5.9mag --------- 16.90
jrc4y4 -------------- 15.30
Turbo440Dart ----- 14.70
Curious Duster ---- 14.50
red67gts ----------- 14.40
a-bodyguy --------- 14.319
junkyardhero ------ 14.00
fishmen67 --------- 13.80
273 ----------------- 13.70
331MP ------------- 13.40
RustyRatRod ------ 13.016
15.0 Bob
Love it.... keep 'em coming. 318willrun will give away a nice gift for whoever gets it the closest. All ties will go to the lower ET - example: If it runs 14.05 and there is a 14.0 and 14.10 guesses, then the 14.0 would get it. Also, if more than one person guesses the same ET, then each person that guesses after the original will get a .001 add to their guess.
71GSSDemon ----- 15.00
oh yeah! Your going 14’s my guess is (14.2)
floating valves on the big end like a champ. Do your home loving on the bowls and a hasty back yard back cut on the valves with the heads off. True hot rod gritty fairy dust and prayer 14.2
Ha! But it's first getting sent as it is..... :) Gotcha down for a 14.2 ~
67/6barracuda ---- 14.20
@TT5.9mag flies his magnum flag proudly so he won’t give that 440 any credit.
I love me some big block. But not when they’re stock and yanked out of an rv. Like that they barely will pull a greased string out of a cats ***. I do fly the magnum flag pretty hard though. I am a fan.
If a stock motorhome 440 runs 13.0x in @440willrun’s truck I’ll sell every magnum I own and start buying RVs.
:lol: deal. And if it goes 16.9 or slower, I will literally let my wife beat it with a sludge hammer and it will be a video on my channel
Are these guesses for first run down the track or best run of the day after tuning? Or ? What gear will it have? What is the rest of the combination that you will have in it when it counts for the contest?
I will tune it my best and it's best run will be the counter. That's only fair to the RV :)
RV 440
. Stock cam, internals, and block, and wearing the 452 heads. It did have one rusty cylinder, I removed that piston and honed that one cylinder so.....LOL. Here is what I did before installing it in the '79 Magnum:
  1. 440 Torker intake on it. I do have the factory cast intake.
  2. 452 Heads . I had a valve job done, new springs, and I did touch the casting up some with a dremel but I wouldn't say "ported". I also, to make up the difference in the thick gaskets I used vs factory, cut them .030 so should be same as stock compression (very low..lol).
  3. Installed a new timing chain. I did go 2* advanced when i installed it, but probably back to TDC after running it for a bit here and there. LOL
  4. I'm using the carb off the 5.9. 750 DP.
The Truck - as it sits with the 5.9. Same converter (cheap off the shelf hughes). I may pull the 4.30's for something like 3.23's if it runs out of lungs by the 1/8 mile... lol
I'm gonna go 14.81secs., best time as is, will depend on how much it likes the headers....
Jim K6
Jim K6
Killer6——————- 14.81
Jegs arrived…. Summit should be here real soon.
Black Friday sale at Speedmaster.... I ordered SS 1.5 rocker set up for the 440... for down the road
