You guys need to just build stuff. Dyno's and theoretical stuff can or can not help. A guy I know was racing dirt track with a 318 and 340 X heads, had the fastest car on the track. That test is questionable at best. My experience is the same as 318willrun, 340/360 heads with any either 1.88 or 2.02 intake valves takes a 318 to the 340 level. I always had the heads milled .040 and .038 intake side to keep the compression the same or better. Of course you also need the cam, valve springs, intake, carb, and distributor.
