Hot ballast resistor and smokin. no start at all when turning key
Goes the harness have plugs for your electronic ignition and electronic voltage regulator like it should
Ok so where does it go
You'll need to check with who built the harness since it's an aftermarket kit. This is either feeding 12v power to the field coil and voltage regulator, or it's taking power from the field coil and sending it somewhere, most likely the ignition coil. If it wasn't plugged in, though, it's not what made the wire smoke.
Anyway l could eliminate that,run the blue voltage regulator wire to alternator? The the blue wire just be a single wire instead of a double blue wire.
Never had it plug in that other terminal,don't where the blue wire goes you saw pics
Have you checked if that terminal is shorted to ground yet?
A single wire would just need whatever is on the other end to be fed 12v switched power from that side - typically a double wire on the voltage regulator instead. But your harness may already be doing this.
Yah the terminal was loose on alternator,l tighten it back up. That would cause it short out and melt that wire? Ok l can eliminate the double blue wire and make it a single wire then?
Only if it touched the housing. Please unscrew the blue and green wire and measure the resistance from the terminal to ground with a multimeter to be sure the problem is gone
Ok l see l will do that,l was able to move it back and fourth the terminal with my finger before l tighten it up.
Blue wire keeps getting smoked,go and try started it,that blue wire that goes to the alternator from voltage regulator smoked down the copper. Only wire that did
Did you measure the resistance with a multimeter? What was the result?
