[WANTED] Driver Side Door Jamb “Striker” plate
tubbedamx
Location Boise, Idaho
Boise, Idaho
Looking for Driver Side Door Jamb “Striker” plate for a ‘67 Barracuda.
Must be complete and be able to be disassembled.
Shipping to Boise Idaho 83709
PayPal ready
Thanks
They are not side specific if you are just using the pieces and not the jam section.. The early ones just used the metal holder without the heavy reinforcement plate circled. Just find a jam with 1 like I did or build your own plate and weld your holder to it. Then slip in from backside and weld on.
You are better off using the correct side so the outer metal can be left attached to the striker and bracket and butt weld it in as a unit with the correct contours for locating it. I may have one on a car here but weather is holding back part removals and we are getting 24 more inches Sunday. I'll look later today to see if there is a good one on a car here. I am leaving to take my grandsons home. So it will be when I get back Steve
That’s great thank you
