I'd rather they get in there and fight the fire than wait for it starve for air, which it ain't gonna do.
"Oxygen limited" or "ventilation limited" is a phase of fire that happens all the time. Leaving the door open guarantees the garage will fully involved in minutes, often faster than the response time of the fire department.
Again, this is literally something I've seen firsthand on many occasions. Fires can literally burn themselves out in rooms where all the doors and windows are closed. This is obviously dependent on a lot of different factors, but it really does happen and it's not rare. And even if the fire doesn't burn out, as soon as the oxygen level starts to drop the progression of the fire is slowed. That can happen within minutes in a closed room (again, faster than most departments can arrive).
What will happen if they leave the door closed? They'll wait for it to burn through the roof and THEN try to put it out. If the roof is gone, shut off the water and go home. There ain't no salvaging that.
Nonsense.
As I mentioned earlier, any capable firefighters can be through your residential garage door in under minute or two at the most. In areas with professional departments that can put several units on scene quickly the door is often taken down while other firefighters are deploying the hose, so water is applied simultaneously with the opening of the door. You're not waiting on one firefighter to force the door and then go back and deploy the hose and get ready to fight the fire, it all happens at the same time. Also, garage doors frequently fail under heat conditions well before the fire goes through the roof, especially in a finished (sheetrocked) garage. Garage door tracks warp easily with exposure to heat and then the door panels can be pulled down with just a hook. And there are other methods to use in the case of small fires that don't even require serious damage to the door, but again, I'm not going to describe all of them here because they can be used to enter peoples garages.
No one with even the most basic training waits for it go through the roof to start fighting fire.
Edited, I guess the discussion is more about leaving it closed before Firemarshall Bill shows up. It'll be open and I'll be dragging out what I can.
Ain't nothing in my garage worth dying for. If it's big enough you can't put it out, don't go back in,
period. Plenty of people die going back into fires after they've already been out. If you wouldn't trade your life for it, stay out. Smoke kills people well before the fire has progressed to the point where the heat will keep you from going in.
