904 Overrunning Clutch Inner Race Compatibility
340inabbody
Arizona
I have had to put on hold my transmission overhaul to help a sick friend. When I finally got back to it I can’t find my Overrunning Clutch Inner Race. I have turned my place upside down and I only recall cleaning it off.
Anyway this is for my 1987 Lockup 904.
I have one from my original 1970 non-lock up 904 with 24 teeth pictured below.
QUESTION: Is the 1970 non-lockup inner race the same as the one used on a 1987 lockup?
The 24 teeth race in a 1970 A904 transmission, Chrysler part number 3420023, is the same as the 1987 A904 lockup transmission with the same part number, 3420023.
Race number 3420023 was used 1969 - 1988. However, 1969 - 1971 A904 transmissions could be built with either the 24 teeth race or a 47 teeth race, part number 2808668.
well it’s almost midnight. I don’t give up easily. I found the missing race. Wouldn’t you know it….it was in the last place I looked!
Confirmed its a 24 tooth unit, the same one that was in my 1970 unit.
Thanks for the confirmation and background infor @Vaanth !
