what fits? 71 duster 318 exhaust manifolds?
abodyjoe
Berlin,N.J. 08009
what manifolds will fit a 71 duster with a 318 in it? i can get a set of 74 challenger 318 manifolds for free. will they work?
****, i don't know. i thought the a and e body 340 manifolds were the same.. i don't remember now..lol
Nope. What does yours look like? If it's a bonafide E body, it dumps in the rear. The A body has that kinda snakey outlet that dodges the steering column.
Look at the exh manifold casting list on the board. Pass side is no issue with a center dump. I believe you are good to go with the E body Manifolds.
Yes, buy those $850 piece :rolleyes: :lol:
$250 plus the ship. I sandblasted them and was going to install on my Duster but went with headers instead. Have a coat of Thermotech high temp aluminum to keep from rusting. The drivers side had a small crack near the center flange, friend of mine ground it out and welded up.
In general, exhaust manifolds from many small block applications fit the right side, but the left side is specifically A-body, with a few different possibilities. The following listings include various exhaust manifolds that can fit. Variation highlights are listed, but smaller variations occur over the years and applications. Mating head pipes and/or attachment generally interchange within specific body types, but various "tweaking" might be needed. The early 340 exhaust manifolds have specific head pipes, particularly for the right side.
This fitment listing is generally the same for any 1967 - 1976 A-body.
318 Exhaust Manifolds
  • Right side:​
    • 1967 - 1974 A-body, noting the following:
      • Heat riser changes, mostly pre 1970 and post 1969
      • Later stronger castings
    • 1975 - 1976 A-body, noting the following:
      • With or without air pump provisions
      • Casting ribs
      • Heat riser
    • 1967 - 1974 B-body, noting the following:
      • Slight difference for 1973 -1974 Road Runner
    • 1975 - 1976 B-body, noting the following:
    • 1970 - 1974 E-body, noting the following:
    • 1967 - 1974 C-body, noting the following:
    • 1975 - 1976 C-body, noting the following:
NOTE: Right side for 1977 - 1979 B-body, 1977 - 1978 C-body, 1976 - 1980 F-body, 1977 - 1989 M-body, and 1981 - 1983 J-body are possible, but are physically larger externally, have air pump provision considerations and other variations.
  • Left side:​
      • Slight difference pre 1970 and post 1969
      • Heat stove provisions 1970+
      • Revised 1973 - 1974 heat stove provisions
273 Exhaust Manifolds
  • Right side:​
    • 1967 - 1969 A-body, noting the following:
      • Heat riser is different than 1971
    • 1967 - 1969 B-body, noting the following:
  • Left side:​
360 Exhaust Manifolds
NOTE: 360 manifolds typically have larger internal porting, especially the left A-body version.
  • Right side:​
    • 1974 A-body
    • 1972 - 1974 B-body
    • 1974 E-body
    • 1971 - 1974 C-body
  • Left side:​
NOTE: Right side for 1977 - 1979 B-body, 1977 - 1978 C-body, 1976 - 1980 F-body, and 1977 - 1980 M-body are possible, but are physically larger externally, have air pump provision considerations and other variations.
340 Exhaust Manifolds
NOTE: 340 manifolds typically have larger internal porting 1968 - 1970 were larger and flowed better, with the right side uniquely shaped. The left side changed for other body lines in 1971, but largely remained the same for the A-body version.
  • Right side:​
    • 1968 - 1970 A-body, noting the following:
      • Large difference from later version, flat pipe flange
    • 1971 - 1973 A-body
      • Similar to 318 with larger porting
    • 1971 - 1973 B-body, noting the following:
    • 1972 - 1973 E-body
  • Left side:​
    • 1968 - 1973 A-body, noting the following:
      • Heat stove provisions 1972+
The right side from the 1974 Challenger will fit. The left side will not fit.
The following image is the 318 left manifold style used in the 1974 Challenger and other non A-bodies:
The following image is the 318 left manifold style used in the 1971 Duster and other A-bodies:
these say they do. maybe the 318 is different.
MRE - 340 Exhaust Manifold Set
Fits: 68-70 340
340 Exhaust manifolds PN#2863549 and PN#2863553
Used on 68-70 A-BODY and 70 E-BODY cars with 340 engine
The 340 exhaust manifolds were originally designed for the 1968 A-body and that style, for which the Mancini reproductions are made, was used in 1968 - 1970 in A -bodies with 340, and in 1970 E-bodies with 340. In 1971, the right side changed to the smaller, simpler, but more restrictive exhaust manifold for all 340s. The left side also changed for non A-bodies, but the A-body retained the large, better flowing style due to the space situation on that side in the A-body engine compartment.
In short, you want a 1967 to 1974 A body 273 or 318 drivers side manifold. The earlier the cleaner. On the passenger side most any 273 or 318 center dump exhaust manifold will work. I assume you want to run the factory exhaust to start. This leaves out all 340/360 exhaust manifold, unless you run the rest of the 340 exhaust system.
anything i can get my hands on will work.. 340 manifolds if i find them affordable i'd do, if not 318 manifolds will be fine.. there is no exhaust on it at all so that doesn't make a difference either/
340 T/A and AAR cars in 1970 have the same manifolds as the 68-70 340 a-bodies. All other e-body 318 340 and 360 cars the drivers side is different
The 70 model 340 four barrel cars also had the 340 HP manifolds like used on TA & AAR's and in A bodies. In 71, they went to the rear dump drivers side manifold on the 340 cars and retained the rear dump drivers side 318 manifold throughout the E body run. Also starting in 71 on 340 E bodies, they used a center dump passenger side manifold with a 2.25 flange.
I have a pair of exhaust manifolds from a 71 318 duster. West coast though so shipping is something
I got some on a 69 273 valiant. They should work. I have a flat rate game box that they should fit inside.
