mechanical fuel pump
leblanc
member 2883
Dieppe, New Brunswick, Can.
After the guidings of our FABO members I have decided that mechanical is the way to go. I will try another one because the first one (new) had a bad diaphrame inside from what we could tell as it had no suction or push. Now which one should I use. Iwould like a decent one but probably not Holley because they are too expensive for my budget and the car won't see that much use anyway.
http://www.rockauto.com
CARTER Part # M60514
{Mechanical Fuel Pump}
getimage.php
$27.79
Thanks guys!
Looks like everybody agrees on Carter so Carter it is and oh by the way I found the Carter M 60514 at Auto Part Giant.com for 22.33 instead of 27.79...My application is basically stock, about 300 HP
Thanks guys!
OK, so i know I'm waking a long-dead thread here, but im pulling my hair out trying to find the right fitting to mate up to the outlet on the 60514. You guys have any advice?
