MoparSteve
Hate to do this, but need to make room in the garage. So here it goes.
69 Dart. 440 running 9.5:1 compression with mild Crane cam has less then 2K miles since rebuild. The 440 was a HP motor originally from a 72 Plymouth, Heads has hardened seats. Holly intake manifold with Eddy 750 electric chock and TTI headers. 727 Tranny with 2000 stall converter from B&M. The rearend is a 8.75" from a 66 B body with spring relo and has Richmond 3.91 SG. Custom heavy duty drive shaft. Custom 9 qt oil pan.
Manual breaks and steering, front disc rear drums with all new brake components. Frontend suspension has new tierod ends, ball joints, idler and pitman. New BF Goodrich Radial T/A tires with custom widen Mopar rally wheels. 205/70/14" front 245/60/15" rear. The paint job is a 10 footer that is about 12 years old and it is a 94 Dodge Ram Moss Green metallic paint (including engine bay).
Interior is in good condition with new white matching headliner. Battery has been relocated to the trunk. Also has brand new side mirror and tail light bezel. Mechanically, this car is in top shape with good bones. It could use a new paint job as there are some small bubbles starting to show up on lower rocker. And it could use a radio/speakers/antenna or you can just listen to the RB going down the street. Asking $12,500. No trade please.
