jimmyray
- Joined
- Jul 17, 2007
- Messages
- 948
- Reaction score
- 31
I have whined a couple of times about the performance of my 408, which should propel my duster to 11.5's, but the best it's got is 12.13 @ 110.5. The car has always had some excessive crankcase pressure, usually pushing oil out of the dipstick tube, and sometimes leaking past the valve-covers. However, Sunday I was making a few runs, besting at 12.19, but I actually had som much CrankCase pressure it forced the screw-in PCV valve assembly out of the valve-cover, and blew oil all over the firewall. Thinking it was not screwed in correctly, I reinstalled it, and made a couple more runs, and it did it again!! Figuring something was not right, I packed it in and came home.
I've had the stroker in for almost 2 years, and it has over 120 passes on it as well as 5,000 miles, so it's got some use. I bought all of the parts for the stroker from Hughes Engines, thinking I should avoid E-bay and go with the "experts". Well when i got the kit, the crank was slightly damaged from handling by UPS, the main bearings were rusty, and the ARP head bolt kit was mismatched, missing 2 of the longer bolts.
Well, I am now researching the pistong ring issue, and according to the invoice, they sent me stock 4.00 rings with my 4.030 KB pistons. I'm not sure if thats what they actually sent, but that's what the invoice reports (see below).
I have not performed a leakdown test, but a compression test showed between 170-180 on all cylinders.
Any thoughts on the impact of putting 4.000 pistong rings with a 0.026 (corrected, I origianlly wrote 0.022) gap into a 4.030 bore cylinder?
Engine details:
Motor details:
408 cast crank stroker from Hughes
9.6:1 compression
93 Octane gas
mild port/polish on Edelbrock al perf heads, closed chamber, fresh valve job
M1 single plane airgap with gasket match (heads too)
Carter TQ - .102 & .161 jetting, 1.5 primary
Comp roller .544/.541 236/242 110 centerline
FBO ignition, ditributor curved to 16 inital, 34 total @ 2900 rpm
Hooker comp 1 5/8" headers (dented bottoms on driver side, naturally) 3" collector
3" pipes into/out of welded Summit 3" mufflers into a-body tips
4000 9.5 Dynamic Convertor
727 manual reverse
3.73 sure grip in a narrowed Dana
Engine details:
Motor details:
9.6:1 compression
93 Octane gas
727 manual reverse
