anyone run drag radials
RyanUpdike70
North Vernon Indiana
I just order a set of mickey thompson et street drag radial 275/60/15 i was
told they was a good tire for the street. I have mt 29.5/10.5/15 slicks on it now i needed some to run on the street. I was wondering if anyone else ran these.They are on my 71 duster
I just bought the same tire for street/strip use but haven't run them yet. I would think it would be a fair weather only tire.
The m/t's are an excellent drag radial,so good i got rid of my slicks and run nothing else,but i don't use mine on the street i find them to be way too sticky and they tend to kick up everything on the road,and any thing you ride over ie:paper.cigaretes grass ect..sticks to them.i run my regular radials on the street,which isn't to often seeing as the duster spends most of it's time on the track...
Expect about 4 to 5k miles out of them at the most.
As Stroked340 says, they will pick up anything up to sewer lids!
They Do Hook. They Do Wear Pretty Quick Though. I Ran These The First Season My Son Started Racing. I Went Thru 2.5 Sets For The Season. I Switched To A Drag Slick For The Next Season. I Went Thru 1.5 Sets The Next Season. We Are Not Hard On Burnouts, Spin Them Until They Haze & Pull To The Line.
You Should Get Better Life Out Of Them. I Was Discarding Mine When They Got Down To The Wear Bars.
I am doing some changes to my rear suspension and was wondering if that 29.5 tall tire fit in stock wheelwell and what are you running spring relocators/mini tubes or what?
Well, you bought a 28 inch tall tire which is going to lower your gear ratio substantially. I would have went with the 295/65/15 which is 30 inches tall.
I have MT 20x10x15's on the rear of the Coronet. I was wary about them in the rain around here, but havent had a issue yet
There a great tire thats all that i run is those tires and i got my dad to change to them and he loves them. He runs a 275/60 and i run the 255/60 ET street Radials. I got a season of bracket racing out of mine. They prolly need to be replaced before this season. My dad will prolly get 2 seasons out of his.
i wondering what engine combo u was running if u dont mine sharing
I'M USING A .020 360 WITH KB107 PISTONS SET AT ZERO DECK. STOCK 340 RODS, STOCK 360 CRANK. ITS BALANCED EXTERNALLY WITH A FLEX PLATE & DAMPNER. HUGES SOLID CAM & SPRINGS. OUT OF THE BOX ELDELBROCK HEADS (NO PORT WORK), HOLLEY STRIP DOMINATOR INTAKE & 750 D/P CARB.
1 3/4 HOOKER HEADERS, & A MSD6AL IGNITION.
TRANSMISSION IS A 904 WITH A 2:74 LOW GEAR, MAN VALVE BODY, & 9 1/2 DYNAMIC CONVERTOR.
8 3/4 WITH 3:91 GEARS.
BEST ET WITH THIS COMBO, 11.57 @ 115MPH, 60FT 1.62
I CHANGED THE GEARS TO A 4:30 & CHANGED THE CONVERTOR TO AN 8 IN.
BEST ET WITH THIS COMBO, 11.28 @ 117.5, 60FT 1.48
I will be running 325/50/15s BFG drag radials. The dart is mini-tubbed with a 4-link. Not much clearance.
dam that thiings pull the wheel good I running a 440 with mild head work and cam i have a 4000 convertor with 456 gears i dont no what it going to run though
