Chuckbizkits
I am running a battery shut off switch. Sometimes the car will sit for awhile and I'd like to eliminate battery drain. I would like to run a 5A fused, dedicated line from the + terminal on the switch to the radio (memory). If I do this I will have feed back back thru the line, keeping the main panel energized.
I need to wire in a diode. Can someone please explain EXACTLY how to do this? Does the cathode point towards the + battery or the radio? Do I use a 1N4000 type of diode? Thanks.
