parting a 73 dart swinger in CT LH23 08/72
drive48
MILK MAN
connecticut
many useable parts let me know
disc brakes , interior gold, frames, v8 spool, sway bar, etc.
Im from California 95003
I am looking for a disc brake set, if still available let me know your asking price
thank you
Bruce
What motor ? If it's a 318 , does it have a/c ? I'm looking for non-a/c crank & water pump pulleys . Thank you .
pm sent
How much for the disc brake set up
thank you
Bruce
  1. front upper panels ----- $50.00 set
  2. rear upper panels -----$20.00 set see image of pass side piece mia
  3. a pillar -----$10.00
  4. kick panels -----$20.00 set
  5. door cups -----$10.00 set
  6. visors -----$20.00 set
  7. Column cover 1 hairline ----- $15.00
  8. arm rests 2 rear good chrome ashtrays (near mint), 1 front (back pins mia), good bases for rears and 6 screws -$30.00
  9. rear lower door panels set with wood grain ------$30.00 set
  10. front lower door panels both need new backboards with good vinyl and woodgrain -----$20 set
  11. Inner fenders with cowl mounts still attached -$ 150.00 set
  12. grille with chrome edge and headlight bezels 1 mount tab broken NO BREAKS IN GRILLE ITSELF ----- $85.00
i am listing here before other avenues.
Would you sell the struts that go from the lower control arm to the K member? If so how much?
If 2 Darts passes on the dash pad, I might be interested. I'm in Waterbury, and don't mind putting a Jimmy Hat on a less than perfect pad if the price is right. Mine is literally molten.
pic of the passenger side quarter. i need a patch panel from the center of the wheel well to the door striker.
thanks
need the lower ball joint mounting bolts to spindles. how much. need them real fast if your willing to part with them. Let me know. chicago area 60417.
