pauls340
I have sbp drums on the Demon now. I am redoing sbp KH disc. Will the UCArms work on the disc brake setup? Thanks in advance.
thats a little confused I believe....
DrDiff carries an adapter to allow the use of the smaller balljoint and UCA with the later spindles that use the larger balljoint. It fits over the smaller balljoint stud allowing it to fit "correctly" in the larger balljoint spindles.
