SBP disc brake upper control arm,UCA ?
pauls340
17 miles N of Detroit
I have sbp drums on the Demon now. I am redoing sbp KH disc. Will the UCArms work on the disc brake setup? Thanks in advance.
Yes.
If you were switching to the bbp brakes from a 73 up then you need to swap the upper control arm in from the 73 in addition to all the brake stuff.
73 up uses a bigger upper ball joint.
However there is an adapter available which makes it possible to mate the bigger 73 up ball joint to the sbp upper arm
thats a little confused I believe....
DrDiff carries an adapter to allow the use of the smaller balljoint and UCA with the later spindles that use the larger balljoint. It fits over the smaller balljoint stud allowing it to fit "correctly" in the larger balljoint spindles.
Umm yup thats what I meant! Thanks Jimacuda..
