[SOLD] Parting 74 Duster
prrc
Indiana
I have a 74 Duster I will be parting out. I'm using the disc brake set up and the rearend.
Other than that everything is up for grabs. Its an X race car so not much interior left.
Heres what I think is of use to someone.surprisingly the trunk and rear rails are in good shape.
V8 K member 200.00
3 Fenders1 left 2 right all in pretty good shape. 50.00 each
Hood has a shoop riveted to it. 50.00
4 speed trans tunnel. 50.00
4 speed pedal assembly.100.00
Doors with glass and regulators. 100.00 each.
Rear glass 50.00
rear side glass 50.00 for the pair.
Bumper straight. need re chromed. 25.00 each
power steering gear box 25.00
Aluminum manual gear box 25.00
Condition on both gear boxes. unknown.
Also just found the trans cross member. Not sure if it's differant for the 4 speed. But I have it also.
All parts are plus shipping to your address. If you see something you need just ask I will do my best to discribe the parts condition.
Quarters are shot. loors need replaced. This car could be saved if anyone is intersted.
I would let the whole car go minus what I want off the car for 350.00
Door panels are shot. No dash pad. The plastic oieces above the door panels look pretty good.
The steering column is gutted. Some one has taken parts from it in the past. anly thing there is the tube /shaft/steering wheel.
If you see something on the car you would like. Just shoot me an offer. I really want to move the parts and or the car.
Yes was a v8 car. Make an offer. I really want to hey the car patted out thanks Tim
how much for the pair of bucket seat covers? i think i see one "crumbled up" in the trunk and the other in the car??? thanks! ps, was the car manual or power steering? i REALLY need the steering shaft from it(not the whole column you can sell the rest)....
I have a 75 duster i need frt. fenders and bumper for. i'm in northern cal. Definately interested!
What are the height width and length dimensions of the scoop? Thanks.
Sorry guys have been at the Monster mopar show today. I will PM everyone with a responce
If you're willing to cut out metal, hows the drivers side lower window channel? I'm in need of a patch for my 71. Let me know.
I am in need of both front arm rests, Pass side upper plastic part of the door panel, the drivers side inside door handle cover and the 4 pcs of plastic trim that goes in the door openings at the pinch welds. Thanks
73 Duster
96 Dakota 4wd
2013 Dart
Interested in the the whole front clip if it is still somewhat intact....rust no big problem
No fenders, hood, etc, or suspension. ...from A pillars and behind the trans crossmember forward.
No shipping, I will pick up.
Could you cut out the truck rod brackets? The part that attaches to the wheel tub and the speaker area?
