Hemi Denny/Alter-K folks
inkjunkie
Safe to assume a rear sump oil pan can be used?? Hopefully will be pulling the trigger on one of these front ends here in the next month or so. Lot of things to consider. Like the fact that with the HD kit track width does not increase. But I like the fact that the Alter-k has its own upper shock mounts. My car has a cage with the snout bars tied into the upper shock mount so the Alter-k's upper shock mount probably is not that big of a deal.....
Yes, you can use a rear sump oil pan. I have a 360/408 with a moroso 7 quart oil pan, side kick outs. Clears everything fine. AlterKation.
center or rear sump on the HDK....with the center sump you can utilize the optional rear brace (where the drag link normally resides)
That was one of my questions I have for you, the rear brace in the pictures...it is optional?
yes.....only used when you have the space. Jims HemiDemon does not utilize it.
it was just I saw the space and thought....why not?
can an alter k be used with a /6 ?
Might want to contact Hemi Denny, I asked him about this a while back....Looks like he is putting mine together, I got this picture from him the other day....
How does one get a hold of Denny's Hemi for suspension prices and what he offers?
Bill
