manifold bolts/washers
Valiant63
Early A-body Valiants
eastern, PA and central Florida
Anyone know where I can buy the exhaust manifold bolts to put the intake and exhaust back on a slant in a Valiant that I bought without manifolds? The triangular shaped washers are where I am mostly stumped. Does anyone sell these? I have a junk engine nearby, butt no manifolds on it either.
why not just use ARP header bolts. you can get them just about anywhere. I got mine from totallystainless.com
The studs in the head are probably an Ace Hardware item, though I would look for better Grade 8 studs. They might interchange with V-8 studs. I am guessing you are mixing up terms and really need only the washers (nuts at any hardware). There is a great write-up on www.slantsix.org (can find links here). The outer exhaust studs have thick round washers. You install the triangle washers with the bulge away from head (I recall). If you don't do it right, the exhaust manifold can crack.
As far as where to buy the washers, I don't know. Seems I have seen them though. Check the dealer since slant engines were used into the mid-80's on trucks and vans. One co-worker in the 90's bought all new ones for his Dodge truck at the dealer since his manual said to not re-use the washers. First time I ever heard that, and I expect most people here re-use them, but it does suggest dealers would have stocked them.
If you find out how many of each you need. I can look and see how many I have. I'm referring to the washers.
I have a few of the OEM D washers with conical sides. I'm not sure if what I have are the ones you need though. If my memory serves correct these are 5/16 in one application and 3/8 in another. Not even sure which/what size I have here.
If we figure out you can use them, You're welcome :)
