Nite Moves
I have a assortment of stuff i want gone. Im not in need and some are. Seat belt covers,black each have a cut same side, $5 for the pair. Asst of seat belt bolts $3 for all. Wiper motor trans.linkage bushings and clips, (3 speed)have 2 $5 each, Horn $5, asst of clips in last pic, $2 for all,trans arm to wiper motor $5 (3 speed), shift lever and strg. wheel nut $2,Equus temp gauge. (overspray and needs line to work) $5,W/W nozzles and fittings $5,black arm rest ,pull $5,asst. door panel clips and bulbs and new rear harness, $3 for all.Black upper window trim. pass. side $5, used Tlamp housing gst $1. All these plus the ride from Ont. Canada. Thanks Fabo. Have a few more items adding pics soon.
