[SOLD] Misc items $5 and under. Garage clean out
Nite Moves
Belleville,ontario,canada
I have a assortment of stuff i want gone. Im not in need and some are. Seat belt covers,black each have a cut same side, $5 for the pair. Asst of seat belt bolts $3 for all. Wiper motor trans.linkage bushings and clips, (3 speed)have 2 $5 each, Horn $5, asst of clips in last pic, $2 for all,trans arm to wiper motor $5 (3 speed), shift lever and strg. wheel nut $2,Equus temp gauge. (overspray and needs line to work) $5,W/W nozzles and fittings $5,black arm rest ,pull $5,asst. door panel clips and bulbs and new rear harness, $3 for all.Black upper window trim. pass. side $5, used Tlamp housing gst $1. All these plus the ride from Ont. Canada. Thanks Fabo. Have a few more items adding pics soon.
Could not fit all in at once. Lower portion of window trim rear Dart, some pitting. $5 for both pieces. Door cyl. clips, new grease fittings 1/4 inch. exhaust manifold washers, new 904/727 dip stick tube seals $3. Thanks for looking .
Temp gauge, arm rest/pull,rear lower rear window trim,trans arm wiper motor, t/lamp gskts and innr pass.side trim piece are left. Moved seat belt covers to different add. Thanks FABO
I have the trans.arm (wiper) frt pass side pillar trim, grease fittings(1/4inch), black arm rest pull,horn left. HOWS $10 for everything plus the ride. Like this stuff gone. Its all ready to go. Thanks
