dibbons
Purchased a second hand factory 1972 four-barrel (Thermoquad) intake manifold. I notice on the underside there are two threaded holes. It that for a heat shield to keep oil off the bottom of the manifold? That would get hot there anyway because of the exhaust heat crossover passage, wouldn't it? Thank you.
