ssba
890-891on there now. Not sure of their application. Just using something I had
already to keep the project moving forward.
I really don't know how many lbs I have taken out of the car but it has always
been on my mind while choosing the parts to use. It will have fiberglass frt fenders and
a pin on fiberglass hood with some sort of vintage scoop from the era.
It seems to be a trade off in some areas. Weight vs strength. Cost is always a factor also.
The bell housing for example would be lighter if an aluminum one were used but I chose a hydo formed ansen scatter shield due to safety and the era correctness it adds to the build. It weighs about the same as a lakewood. Not lightweight at all.
I am using a sheifer aluminum pressure plate and flywheel. These save some lbs.
The transmission case is aluminum direct connection parts.
I do have the 1971 Mopar heads. They are aluminum and take the stamped
aluminum covers.
Other light parts are the race hemi water housing & moroso under drive pulleys.
Aluminum water pump is a modern offering from Mopar. The aluminum weiand tunnel ram and dominator carbs probably don't save much weight.
I will be weighing the car when done to see how close I get to A/MP specs.
aluminum covers.
