Dennis Gerard
do you need a special tool to remove the 3 strange screws holding the tube to body?
68 barracudaOn what?
This is on a 68 Barracudado you need a special tool to remove the 3 strange screws holding the tube to body?
No, just a Phillips head that fits the screws
these are not phillips heads round with 4 cuts on outside edge
strange screws
What I did to remove (from the backside), found the tool to install.Yep, security screws.
I would be tempted to use a good needle nose pliers and grab two of those slots and gently try and turn them out. Go easy so not to damage the head.
What I did to remove, found the tool to install.
Thank you, planning on cutting these that are in there and ordering those new ones
Alan
