Slant Six Manifold Flared Nuts
Rich Signet
Long Island
Does anyone know where to find,and the size of the flared nut that holds the manifolds to the head on a Slant Six?? I broke one off
Are you talking about the triangular shaped washers? If so, I’ve got a couple of dozen laying around
Are you talking about the two on the ends? If you are, I'm not sure what you mean you broke it off...
I think the stud broke off and they need the nuts. I have some used ones, but nothing new.
This guy?
Thanks Guys. I found the flared bolt on McMaster Carr. I realized that I also have a broken washer, like the one to the right on the photo Cuda416 attached. Also, does anyone know where to get a radiator for a slant 6?? The bolts spaces are 21 1/4" side to side and 11 1/2 inches top to bottom bolts. I tried Classic Industries with no luck.
I have 2 slant rad.I got from O Reilly. No need to go to old car vendor.
Thanks. I’m good on the nut. By chance do you have any washers for the manifolds(
I don't think those nuts are the same. The stock ones are a cone shape. I will post a picture tomorrow. Not saying those won't work, they are just different.
I’m looking for the cone shaped. I have to bolt the manifolds up. I’m also looking for a radiator. I looked at the O’Reilly website, but couldn’t find 63. And ideas on radiators?
I think he is looking for the far right one in the middle row of the picture Cuda415 posted on post #5.
Only rad. I found was Rock auto for 67 dart rad has core height of 17 3/8 in. which is probably taller than oem for your 63. ut might work, you just need to measure The width should be same, but yo might have to drill a few new monting holes. WHO hit the caps!!???? 63-6 a body should be same, 669 same, not saying a rad for a 70 duster will not work. I have bought slant rad new from O reilly for 71 duster, 79 volare in last 2 years. I had several 63-5 darts and cuda slant cars couple years back, and NOT sure what I did for rad back then.
I have some of the cone bolts if you can't find them.
I could not find a rad for my 62. Had the original re-cored, ouch! Of course I wasn't going to drill any holes to fit another one in this car.
Thanks for the info. For the Radiator, I’m trying to get one that will fit right in. Prior to me getting the car somebody put in a radiator and rigged up the hoses. For the washer, if you have a cone shaped one, let me know what you want for it, that’s great. Thanks very much.
